BFG Tech GeForce GTX 285 OCX 1GB
Written by Tim Smalley
January 30, 2009 | 12:19
Tags: #285 #article #bfg #card #consumption #evaluation #geforce #gt200 #gt200b #gtx #ocx #performance #power #review #temperature #value
Companies: #bfg-tech #nvidia #test
Crysis
Publisher: Electronic Arts
Crysis is seen by many as the poster boy for DirectX 10 and it will make your system cry, quite literally – it’s a monster! It doesn’t come as much of a surprise then, that the graphics are something special – they’re above and beyond anything we’ve ever seen in a PC game.
We tested the game using the 64-bit executable under both DirectX 9.0 and DirectX 10 with the 1.21 patch applied. We used a custom timedemo recorded from the Laws of Nature level which is more representative of gameplay than the built-in benchmark that renders things much faster than you're going to experience in game. We found that around 27-33 fps in our custom timedemo was sufficient enough to obtain a playable frame rate through the game. It's a little different to other games in that the low frame rates still appear to be quite smooth.
We set all of the in-game details to High and forced 8x anisotropic filtering in the driver menu as there is currently no support for it in game. We tested at 1,280 x 1,024, using 0x, 2x and 4x anti-aliasing, 1,680 x 1,050 using 0x and 4xAA, 1,920 x 1,200 using 0x and 2xAA and 2,560 x 1,600 with 0xAA and 2xAA. By extensively testing using anti-aliasing in very high resolutions in conjunction to Very High quality, we'll be pushing even the bleeding edge hardware on test to the limit.
Crysis
1,280 x 1,024 0xAA 16xAF, DirectX 10, High Quality
  • Nvidia GeForce GTX 280 1GB SLI
  • Nvidia GeForce GTX 295 1,792MB
  • Nvidia GeForce GTX 260-216 896MB SLI
  • ATI Radeon HD 4870 1GB CrossFire
  • BFG Tech GeForce GTX 285 OCX 1GB
  • ATI Radeon HD 4870 X2 2GB
  • Zotac GeForce GTX 285 1GB AMP!
  • Nvidia GeForce GTX 285 1GB
  • Sapphire ATI Radeon HD 4850 X2 2GB
  • ATI Radeon HD 4870 512MB
    • 89.5
    • 57.0
    • 83.1
    • 51.0
    • 79.9
    • 49.0
    • 61.9
    • 36.0
    • 59.1
    • 35.0
    • 58.7
    • 33.0
    • 56.6
    • 33.0
    • 55.2
    • 33.0
    • 49.5
    • 29.0
    • 48.4
    • 25.0
    • 43.9
    • 25.0
    • 36.8
    • 20.0
    • 36.6
    • 20.0
20
30
40
50
60
70
80
90
Frames Per Second
  • Average
  • Minimum
Crysis
1,280 x 1,024 4xAA 16xAF, DirectX 10, High Quality
    • 77.2
    • 48.0
    • 70.4
    • 44.0
    • 67.7
    • 42.0
    • 53.9
    • 29.0
    • 50.6
    • 28.0
    • 50.5
    • 30.0
    • 48.6
    • 29.0
    • 46.8
    • 28.0
    • 42.1
    • 24.0
    • 40.3
    • 20.0
    • 36.9
    • 21.0
    • 30.4
    • 16.0
    • 30.4
    • 16.0
20
30
40
50
60
70
80
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 0xAA 16xAF, DirectX 10, High Quality
    • 74.7
    • 47.0
    • 69.2
    • 45.0
    • 66.8
    • 42.0
    • 51.5
    • 30.0
    • 49.0
    • 29.0
    • 48.7
    • 30.0
    • 46.8
    • 29.0
    • 45.3
    • 27.0
    • 40.9
    • 25.0
    • 39.2
    • 21.0
    • 36.0
    • 21.0
    • 29.8
    • 16.0
    • 29.2
    • 16.0
20
30
40
50
60
70
80
Frames Per Second
  • Average
  • Minimum
Crysis
1,680 x 1,050 4xAA 16xAF, DirectX 10, High Quality
    • 64.6
    • 42.0
    • 56.0
    • 37.0
    • 54.2
    • 36.0
    • 43.1
    • 24.0
    • 41.6
    • 25.0
    • 41.2
    • 26.0
    • 39.9
    • 25.0
    • 38.3
    • 24.0
    • 35.1
    • 21.0
    • 33.1
    • 15.0
    • 29.7
    • 18.0
    • 24.4
    • 13.0
    • 24.3
    • 13.0
20
30
40
50
60
70
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 0xAA 16xAF, DirectX 10, High Quality
    • 62.1
    • 39.0
    • 57.4
    • 36.0
    • 54.6
    • 34.0
    • 48.1
    • 28.0
    • 45.8
    • 27.0
    • 39.9
    • 24.0
    • 38.5
    • 23.0
    • 37.1
    • 22.0
    • 35.9
    • 18.0
    • 33.5
    • 20.0
    • 29.2
    • 17.0
    • 27.3
    • 15.0
    • 27.1
    • 15.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
1,920 x 1,200 2xAA 16xAF, DirectX 10, High Quality
    • 56.8
    • 36.0
    • 49.5
    • 27.0
    • 47.6
    • 31.0
    • 44.4
    • 26.0
    • 42.2
    • 25.0
    • 36.3
    • 22.0
    • 35.1
    • 21.0
    • 33.9
    • 21.0
    • 32.8
    • 16.0
    • 30.5
    • 18.0
    • 26.3
    • 15.0
    • 25.0
    • 14.0
    • 24.6
    • 14.0
20
30
40
50
60
Frames Per Second
  • Average
  • Minimum
Crysis
2,560 x 1,600 0xAA 16xAF, DirectX 10, High Quality
    • 38.5
    • 22.0
    • 33.3
    • 15.0
    • 31.8
    • 13.0
    • 30.1
    • 17.0
    • 29.2
    • 16.0
    • 24.3
    • 14.0
    • 23.5
    • 13.0
    • 22.5
    • 13.0
    • 22.3
    • 11.0
    • 20.4
    • 11.0
    • 17.8
    • 10.0
    • 16.3
    • 9.0
    • 16.0
    • 8.0
20
30
40
Frames Per Second
  • Average
  • Minimum
Although the additional clock speeds make a bit of a difference in very high mode, they don't make much difference when you lower the in-game settings to high. The frame rates at 1,920 x 1,200 2xAA 16xAF are well above 30 frames per second on even the reference-clocked GeForce GTX 285 - the factory overclocked BFG and Zotac cards just deliver higher frame rates - the BFG is seven percent faster than the reference card, which is right in line with the clock speed increases.
null
